ARM7 Philips LPC2000 Debugger Schematics with Keil?
SphinX
Advanced Member level 3
EGYPT
ulink rdi
Salam,
I search schematics for LPC2000 ARM Debugger compatible with Keil uVision3, Any Help?
I know uLink Debugger but it's commercial :-(
Thanks for any help,
SphinX
debug lpc2000 com-port
SphinX said:
Salam,
ULINK shematics and PCB <:D>
Reactions: markbng
    SphinX
    markbng
ulink clone
ULINK does not support IAR ?
iar + ulink
May not be possible. I tried a ULINK clone and found it is not RDI compatible. I am not sure if that is the problem of cloning or what.
John
lpc2000 schematic
Kolia said:
SphinX said:
Salam,
Hi
many thanks Kolia for the schematic :)
but the code for the AN2131Q is missing??
where can i find it???
or it is not important ????
many thanks
Ahmed
ulink.htm
eng_ahmed22 said:
Kolia said:
SphinX said:
Salam,
Hi
many thanks
Ahmed
AN2131Q not use code. It read only VID/PID from eeprom.
lpc wiggler schematics
SphinX said:
Salam,
SphinX
hi SphinX,
Don't know if u have seen this, but i think u are looking to construct one with wiggler.
Here is the link from arm.com which explains an agent with keil 3.0 with wiggler...
https://www.arm.com/miscPDFs/13610.pdf
Here is the place to download the debug agent : https://hjtag.blogspot.com/
All instruction to integrate into keil is given also with a Flash programmer to program the LPC2000 flash ( not using the com port ).
Hope this helps u....
Sam
    SphinX
philips lpc2000
I started to learn Philips ARM7.
In the datasheet i found, the current on any IO pin 4mA, but it is listed on the MIN column. Dont know, how much is the max? Can I drive a LED direct?
lpc2000 can schematics
Hi
Yes,you can drive a 2mA led directly from ARM7 {LPC21xx} I/O pin
But use no more the 2 LED's since it's not designed to drive LED's
If you wish to drive high-intensity led use a FET driver like 2n7002
Best regards
Bobi
phillips lpc2000
Thanks a lot!
Added after 14 minutes:
ULINK shematics and PCB <>
Where is the PCB?
wiggler clone pcb
keil rdi
dainis said:
h**p://aly.projektas.lt/Tools/ULink/Ulink.htm
it's a pity! i can not open this website.
schematic io pins on arm7
Hi zhongyb,
pls have alook at what koila has uploaded... it is the same download form the website given above
Sam
keil arm 7
Is there any document about RDI1.51 protocol? I searched a long time but not found yet. I'm interestinig in the RDI protocol and want to study it.
Thanks!
wiggler arm keil
I made a ULINK successfully,it works with Keil RVMDK perfectly.
ulink2 schematic
Can you post your scheme please?. I only have a Wiggler clone.
lpc2000 schematics
Salam,
Do you have ULINK2 schematics?
If you have,can you post a copy to me?
Thank you very much.
My E-Mail:fyp0303@163.com
Added after 2 minutes:
Kolia,
I've made a mistick.
I am very sorry.
My E-Mail:fyp0303(at)163.com
