ARM7 Philips LPC2000 Debugger Schematics with Keil?
SphinX
Advanced Member level 3
EGYPT
ulink rdi
Salam,
I search schematics for LPC2000 ARM Debugger compatible with Keil uVision3, Any Help?
I know uLink Debugger but it's commercial :-(
Thanks for any help,
SphinX
Kolia
Newbie level 5
debug lpc2000 com-port
SphinX said:
Salam,
ULINK shematics and PCB <:D>
Reactions: markbng
    SphinX
    markbng
SPATAN
Full Member level 2
ulink clone
ULINK does not support IAR ?
TechToys
Full Member level 2
iar + ulink
May not be possible. I tried a ULINK clone and found it is not RDI compatible. I am not sure if that is the problem of cloning or what.
John
eng_ahmed22
Full Member level 4
lpc2000 schematic
Kolia said:
SphinX said:
Salam,
Hi
many thanks Kolia for the schematic :)
but the code for the AN2131Q is missing??
where can i find it???
or it is not important ????
many thanks
Ahmed
SPATAN
Full Member level 2
ulink.htm
eng_ahmed22 said:
Kolia said:
SphinX said:
Salam,
Hi
many thanks
Ahmed
AN2131Q not use code. It read only VID/PID from eeprom.
sam_manchali
Member level 4
sharjah
lpc wiggler schematics
SphinX said:
Salam,
SphinX
hi SphinX,
Don't know if u have seen this, but i think u are looking to construct one with wiggler.
Here is the link from arm.com which explains an agent with keil 3.0 with wiggler...
https://www.arm.com/miscPDFs/13610.pdf
Here is the place to download the debug agent : https://hjtag.blogspot.com/
All instruction to integrate into keil is given also with a Flash programmer to program the LPC2000 flash ( not using the com port ).
Hope this helps u....
Regards
Sam
    SphinX
NickE
Member level 1
philips lpc2000
I started to learn Philips ARM7.
In the datasheet i found, the current on any IO pin 4mA, but it is listed on the MIN column. Dont know, how much is the max? Can I drive a LED direct?
bobcat1
lpc2000 can schematics
Hi
Yes,you can drive a 2mA led directly from ARM7 {LPC21xx} I/O pin
But use no more the 2 LED's since it's not designed to drive LED's
If you wish to drive high-intensity led use a FET driver like 2n7002
Best regards
Bobi
zhongyb
phillips lpc2000
Thanks a lot!
Added after 14 minutes:
ULINK shematics and PCB <>
Where is the PCB?
zhongyb
keil rdi
dainis said:
h**p://aly.projektas.lt/Tools/ULink/Ulink.htm
it's a pity! i can not open this website.
sam_manchali
Member level 4
sharjah
schematic io pins on arm7
Hi zhongyb,
pls have alook at what koila has uploaded... it is the same download form the website given above
Regards
Sam
czm_88
Junior Member level 2
keil arm 7
Is there any document about RDI1.51 protocol? I searched a long time but not found yet. I'm interestinig in the RDI protocol and want to study it.
Thanks!
zhoupxa
wiggler arm keil
I made a ULINK successfully,it works with Keil RVMDK perfectly.
folks
Full Member level 3
Guadalajara
ulink2 schematic
Can you post your scheme please?. I only have a Wiggler clone.
fyp0303
Newbie level 2
lpc2000 schematics
Salam,
Do you have ULINK2 schematics?
If you have,can you post a copy to me?
Thank you very much.
My E-Mail:fyp0303@163.com
Added after 2 minutes:
Kolia,
I've made a mistick.
I am very sorry.
My E-Mail:fyp0303(at)163.com
