ARM7 GPIO and port selection
manvindar
Member level 1
Member level 1
Banglore
hi i am newbie for ARM Microcontrollers....
i want to know how can i select a particular pin for making it high or low
like what should i do to make port 0.22 high...
IOSET0 = 0x00FF0000 <-what should be the value for pin 0.22 and how to select any other pins
how to make a port i/p or o/p
like in this command "IODIR0 = 0x00FF0000"
and how to read a port if its a input port
thanks
You didn't mention the specific device but these should work
IODIR0 |=  (1UL<<22) ;  // set bit 22 of the direction register to 1, this makes P0.2 an output
IODIR0 &=  ~(1UL<<22) ;  // clear bit 22 of the direction register (set to 0), this makes P0.2 an input
//You can also set multiple pins
IODIR0 |=  (1UL<<22) | (1UL<<5) | (1UL<<10) ;   // set P0.5, P0.10, P0.22 to output
IOSET0 = (1UL<<22);  // set P0.2 high
To read a specific bit
if (IOPIN0 & (1<<22)) {}  // true when P0.22 is high
There should also be a clear register to clear a bit
IOCLR0 = (1UL<<22); // set P0.2 low [/CODE]
Reactions: pasicr
    pasicr
i am using lpc2129....do i need to #define something?
and how to calculate the port number like IOSET0 = 0x00001001 <-how this is calculated,,,
Sorry, I don't read previous post,
ARM Wiz is very useful app's (I attach for you), but your ARM model LPC2129 is not supported,
but maybe you will find some help in the future,
best regards
  • ARMwizard_v1.3.rar
#include <LPC21xx.H>
int main()
  int i;
  PINSEL0=0x00000000; //port 0 set to GPIO
  IO0DIR=0x00000001; // 0th bit of port 0 will act as o/p
    while(1)
      IO0SET=0x00000001;   // LED will glow
           for(i=0;i<100000;i++); //to create some delay
      IO0CLR=0x00000001; //Led will off
what change should i make to glow pins which i desire
MOD: Please use code tags in the future
That version is very old, I have added several new features since then.
For the latest version (v3.3.0) download from the homepage **broken link removed**
Maybe your delay is small and need to increase it.
How exactly are you using the pin?
The pins can't provide much current (specs are for about 4mA) so how is the led connected?
Reactions: pasicr
    pasicr
#include <LPC21xx.H>                       /* LPC21xx definitions */
void delay_sec(unsigned int x)
	T0MR0 = x;
	T0MCR = 2;	        // Clear on match
	T0PR = 0x00E4E1C0; // Prescaler for 1 sec
	T0TCR = 0x1;	   // Enable
	while(T0TC < T0MR0);  // wait till match
	T0TCR = 0x0;	   // Disable
	T0TC = 0x0;		   // Precautionally clear the counter
/*void delay (int value)
{                        // Delay function
  unsigned int cnt;
  unsigned int val;
  for(val=0;val<value;val++)
  for (cnt = 0; cnt < 1500; cnt++);         // Delay
int main (void)
  unsigned int n;
  IODIR1 = 0x00FF0000;                     /* P1.16..23 defined as Outputs  */
  while (1) {                              /* Loop forever */
    for (n = 0x00010000; n <= 0x00800000; n <<= 1) {
      /* Blink LED 0, 1, 2, 3, 4, 5, 6, 7 */
      IOSET1 = 0x00FF0000;                          /* Turn on LED */
      delay_sec(1);                             /* Delay */
      IOCLR1 = 0x00FF0000;                 /* Turn off LEDs */
      delay_sec(1);
this code is working and led 1.16-1.23 are glowing sequentially.....
how to change the code to glow 0.16 to 0.23
	T0MR0 = x;
{                        // Delay function
  unsigned int cnt;
  unsigned int val;
int main (void)
  unsigned int n;
      delay_sec(1);
Replace the port direction and pin registers with the ones for port 0.
IODIR1, IOSET1 , IOCLR1 should be replaced
Reactions: pasicr
    pasicr
not working i changed IODIR1, IOSET1 , IOCLR1 to IODIR0, IOSET0 , IOCLR0 but still cant glow pins 0.16-0.22
there is no other change needed in the code so something else must be wrong.
Did you actually try the original code and was blinking the leds?
yes it was working both on board and proteus
but its not working for port 0
I have just tested the following code in the uvision simulator and works fine toggling the pins, there must be something else going wrong with your circuit
	T0MR0 = x;
{                        // Delay function
  unsigned int cnt;
  unsigned int val;
int main (void)
  unsigned int n;
  IODIR0 = 0x00FF0000;                     /* P1.16..23 defined as Outputs  */
      IOSET0 = 0x00FF0000;                          /* Turn on LED */
      IOCLR0 = 0x00FF0000;                 /* Turn off LEDs */
      delay_sec(1);
thank you sir...i had given IOSET0 = 0x00000001 instead of IOSET0 = 0x00FF0000...
sir can you tell me what this 0x00FF0000 means...
like if i want to monitor a port in controller..lets say a switch is connected to it...
then how will i calculate the number "0xZZZZZZZZ" for the port which i want to monitor.....
and can you explain the for loop of the above program...
thanks in advance
0x00FF0000 is a 32bit value written in the hexadecimal format
If you use a converted (like a calculator) to make it a binary value you will get 0b00000000111111110000000000000000
Here is a conversion table https://ascii.cl/conversion.htm
Basically you only need to learn values 0-F which represent 0 - 15 decimal or 0b0000 - 0b1111 , then you can convert any binary or a binary to hex.
From right to left each bit represents one pin of the port
P0.0     0b0000000011111111000000000000000[COLOR="#FF0000"]0[/COLOR]
P0.1     0b000000001111111100000000000000[COLOR="#FF0000"]0[/COLOR]0
P0.2     0b00000000111111110000000000000[COLOR="#FF0000"]0[/COLOR]00
P0.16    0b000000001111111[COLOR="#FF0000"]1[/COLOR]0000000000000000
P0.17    0b00000000111111[COLOR="#FF0000"]1[/COLOR]10000000000000000
P0.23    0b00000000[COLOR="#FF0000"]1[/COLOR]11111110000000000000000
In hexadecimal each digit represents four bits
P0.3:P0.0     0x00FF000[COLOR="#FF0000"]0[/COLOR]
P0.7:P0.4     0x00FF00[COLOR="#FF0000"]0[/COLOR]0
P0.11:P0.8    0x00FF0[COLOR="#FF0000"]0[/COLOR]00
P0.15:P0.12   0x00FF[COLOR="#FF0000"]0[/COLOR]000
P0.19:P0.16   0x00F[COLOR="#FF0000"]F[/COLOR]0000
P0.123:P0.20  0x00[COLOR="#FF0000"]F[/COLOR]F0000
You can also use what I described in post #2
