ARM query (Plz Plz help me)
devendra_devgupta
Member level 3
ep93 iar
Dear friends
Its been a long time here i am aking a question. I am in trouble and yet i have time to get out of it
I am planning to design some thing which is likely to run under hazardous circumstances. I designed it using 8051 using assembly. But now i have to incorporate some new features in it and planning to explore my C knowledge by using it as my programming language. Thus i need to have a fast controller and nothing is better than ARM as you all know
As i am new to it please help me by suggesting the best ARM controller with all its development tools required and their configuration and all those things which are required to know. I have selected st STR7 but i want to share your thoughts on it also
Thanks
Willebul
Junior Member level 3
Africa
winarm optimization
Hi
You cannot go wrong is looking at the Atmel SAM7 series.
Free GNU tools available at hxxp://www.yagarto.de/
hxxp://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/#winarm
with a lot of examplles. You can also buy n nice dev kit for a very low price
wb
mbigdeli
Newbie level 3
Hi
There is no limitation to use well known products!
Follow following link to get GNU tool chains for ARM7 family you can develop with all
free products.
https://www.codesourcery.com/gnu_toolchains/arm
GNU tool chains with Eclipse IDE is best solution for free developments.
Regards
devendra_devgupta
Member level 3
Thanx friends
But One thing i want to ask you that are you using any of these GNU tools for your developmant or you havr seen some other doing these.
Price does't matter but i need quick and fast tools
memarian
Full Member level 5
I used GNU Products (WinARM) for Developing with Cirrus Logic products.it's very good.(because no other compiler supports it's Maverick Crunch FPU Engine)
But i tried before Both Keil and IAR Compilers for speed optimization,after all optimization the IAR speed was 5~10 times faster than Keil.(with the same code)
I'm very pleased with IAR Compiler.IAR has a Kickstart edition with 32KB Limit.
you can use it for free.I think you sould try it.
Good Luck!
devendra_devgupta
Member level 3
Thanx dear friend
Does GNU not support debugging. also there is no user manual of WINarm tooavailable plz tell me something in this regard
If you can suggest any project that makes me more closer to ARM and IAR it will help me a lot
Plz help me
memarian
Full Member level 5
For IAR, Try https://www.sevensandnines.com/ and
https://www.iar.com/index.php?show=92028_ENG&&page_anchor=http://www.iar.com/p92028/p92028_eng.php
WinARM (usually most GNU -Based Compilers) Support Some Devices and their
Special Functions that Commercial Compilers doesn't support them usually.(EX:
I can't find any commercial compiler that support Maverick Crunch FPU engine of
Cirrus Logic EP93xx ARM Processor)
You can also use WinARM Compiler using IAR or Keil or (Some other) IDEs.
You can also use The IAR built-in debugger (depend on your program and your device and Some Luck also!).
For Another GNU ARM Toolchain check
https://www.yagarto.de
For JTAG Debugger you can use H-JTAG https://www.hjtag.com/download.html
Good Luck!
