Oct 31, 2011 #1 A axatraj Newbie level 4 Joined Oct 31, 2011 Messages 6 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,328 Is it possible to do pin programming in ARMPLC2148 like 8051,avr,pic, . I am experienced with 8051,pic,avr but not found any method or bit addressable or pin programming in ARM.so wil u plz help me regarding this issue..
Oct 31, 2011 #2 alexan_e Administrator Joined Mar 16, 2008 Messages 11,888 Helped 2,021 Reputation 4,158 Reaction score 2,031 Trophy points 1,393 Location Greece Activity points 64,371 if you mean something like IOPIN_1 or something like then the answer is no. You can either use shift or use a macro that may make things easier for example IO0SET= (1<<BIT); IO0CLR= (1<<BIT); or #define SETBIT(ADDRESS,BIT) (ADDRESS = (1<<BIT)) and then use SETBIT(IO0SET,BIT) SETBIT(IO0CLR,BIT) Alex
Oct 31, 2011 #3 A axatraj Newbie level 4 Joined Oct 31, 2011 Messages 6 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,328 Thanx Alex....very very thanx.
