ARM assembler for ubuntu GUI
kmegamind
Junior Member level 1
Alexandria , Egypt.
Is there an ARM GUI assembler for ubuntu 12.04 ?, please provide a link or installation commands
sky_123
Your question makes no sense, what does a GUI have to do with an assembler?
Anyway, what you're probably looking for is GNU.
xpress_embedo
India
How can we wrote programs for ARM LPC2148 and program our controller..
Are there any software like Keil for Ubuntu 12.04..
Please reply soon if there is some one..
kmegamind
Alexandria , Egypt.
Sorry i am new to linux, What i meant was an assembler with GUI interface on ubuntu, Some thing like Code blocks but with an assembler instead of a compiler only.
sky_123
I don't know what code blocks are, but you can download GNU tools which include an ARM assembler and compiler.
These tools are based on text files. So, you dont need a GUI. You can use any text editor to create your files, and
execute either the compiler or the assembler from the command line.
I'd strongly suggest using the compiler rather than writing in assembler. There are IDEs available but you need to set them
up, and it's not always straightforward. It sounds like you want something that will just work.
If you are not restricting yourself to Linux and want an IDE, then there is a free size-restricted (32kb) Windows compiler
and assembler with IDE, just go to iar.com. If you're writing in assembler then I suspect your not expecting to write
code beyond 32kb. Both GNU and IAR are good choices.
bigdogguru
Administrator
Southwest, USA
xpress_embedo
India
Thanks bigdog...
This is what i wants...
But now the next problem is programming the lpc2148 develooment board..
I am not having its programmer with me..
It is having serial port bootloader.
And i just use serial bootloafer to program it..
By using lpc flash utility ..
So how can i.use this is ubuntu 12.04
Pls help..
It will be great if i will be able to.nanage aal this in linux
xpress_embedo
India
Hello!!! BigDog..
Actually i want to know the isp programmer you suggest for programming will support my bootloader or not..
This is the steps when my controller is having bootloader and how i program using LPC Flash Utility to program it..
Here is the Snap
Screenshot from 2012-10-07 16:18:53.png
I want to know wthether it will run under linux or not...
And if yes where can i download this software for linux i am having this for windows..
Pls help...
Yes, you can install the Eclipse IDE and ARM-GCC toolchain which provides C/C++ and Assembler development, example:
Using Eclipse to Cross-compile Applications for Embedded Systems
@sky_123 - Code Blocks is an open source IDE for C/C++ development:
Code::Blocks
BigDog
One more problem i am facing is with eclipse..
I follow the tutorial described on the link specified by you and i stuck somewhere in between..
Written in the link:-
Install C/C++ Development Tools
To install the C/C++ development tools (CDT), from Eclipse, select Help -> Install New Software.
In the Install window, under the Work with text box, click "Available Software Sites".
Under Available Software Sites, select these items:
"Eclipse Project Test Site"
Helios Milestone Repository
and click OK.
I didn't find this on my pc
What to do now..
Please help
