[SOLVED] Arithmetic operations
am85
Member level 2
Member level 2
Germany
Does anyone know what's the difference between the arithmetic operations in the FPU and the Multiplier, adder, divider and square root cores in Xilinx Core Generator. I know that with the FPU hardware arithmetic operations could be enabled. Then, are they the same with the only difference that FPU requires microblaze ? if not then which has the higher performance ?
thanks
one of the big advantages of FPGA's is the ability to have simple operations performed in a regular fashion, and with many units.
for example, an FIR filter could make use of 64 multiply-add units (for modern fpgas), and accept new input at 350MSPS (1 new input per clock cycle). Because the operation is fixed, there is no need to have any overhead or coordination from a microprocessor.
the coregen outputs have the advantage that they can be used as needed, usually in large numbers.
In the above, the FIR filter would be possible of significantly higher performace, at the cost of FPGA area. The microprocessor can do anything, as long as it is given enough time.
The difference is in the operation mode. FPU aritmethic is performed sequentially under processor control, one operation at a time. Arithmetic core functions are placed in the data path and operating in parallel. Parallelization involves both higher speed and higher resource utilization.
