Argon and Mixture Filling problem
I am an instrumentation engineer and working in a gas plant where on of the many works is to fill Argon gas and Mixture(Argon+CO2). Recently the plant was tripped due to an indicator ‘Max. Pressure On’, this problem was looked into by checking the complete line for any clogs or substances blocking, safety valves functionality, vent valves, pressure switches, transmitters etc. yet the problem still exists.
A motor is connected near the storage tank for cooling and supplying the gas at a pressure of 157 bars for the multifunction valves near the filling rack and these racks 2 clusters space for filling alternately.
The basic procedure for operating this filling is:
1. Provide Electrical supply to start the PLC and pump
2. Start the cooling of the pump(15 minutes)
3. Then start the motor
4. Fill from the filling racks.
Can you guys help me out to troubleshoot the problem and make it work?
Thanks
Masood Hussain
