Hello,
We have gotten some LED lamps designed and prototyped for us by external design contractors.
The Lamps comprise four LED PCB's , each dissipating ~1.8W.
These PCBs have been glued to a solid vertical aluminium bar, -the glue used is Loctite 382........
Loctite 382 datasheet:
http://tds.loctite.com/tds5/docs/382-EN.PDF
This glue has very poor thermal conductivity and is extremely expensive ($18.51 for ONE SINGLE (!!) 20gram bottle based on 200 bottles quantity)
20 gram bottle of loctite 382:-
http://www.loctite.co.uk/cps/rde/xc...redDotUID=productfinder&redDotUID=1000000IE5R
...not only this, but it has a glass transistion temperature of 120degC, and we're thinking the LED PCBs could get that hot and melt the glue.
We are worried that the design contractor is in cahoots with our competitor, and that this poor choice of glue just compounds our belief.
Do you think they are trying to ruin us by specifying this poor-choice glue?
(it does have the advantage of being fast-setting, but then again, that also means the production staff will have to keep screwing the lid on and off)
