Fazlay Rabbi
Junior Member level 1
I am using arduino uno with itead 3G shield , my shield works fine but it doesn't responding properly ,
After sendint
"AT+chttpact =......"
it back me +CHTTPACT: REQUEST
then when it send GET command it doesn't response at all
What could be the problem ??
here the real response and the code :
Code :
After sendint
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 GSM : Registered to network GSM : Ready for AT command *** Start HTTP Transaction *** +CHTTPACT: REQUEST AT+CHTTPACT="jsonplaceholder.typicode.com",80 Sends Request: GET /posts/1/ HTTP/1.1 Host:jsonplaceholder.typicode.com:80 Content-Length:0 *** End HTTP Transaction *** Memory Free : 1216
Code :
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 // Included header files #include <SoftwareSerial.h> // AT command related #define AT_CREG_QUERY ("AT+CREG?") #define AT_CHTTPACT_COMMAND ("AT+CHTTPACT="%s",%d") #define AT_CHTTPACT_INIT_RESPONSE ("+CHTTPACT: REQUEST") #define AT_CHTTPACT_DATA_RESPONSE ("+CHTTPACT: DATA,") #define AT_CHTTPACT_DONE_RESPONSE ("+CHTTPACT:0") #define EOS ('\0') #define ESC (0x1A) #define OK ("OK") // GSM definitions #define unoTXPin (7) // Uno -> GSM #define unoRXPin (6) // Uno <- GSM #define powerGSMPin (8) #define GSMBaudRate (9600) #define UnoBaudRate (9600) SoftwareSerial gsmSerial(unoRXPin,unoTXPin); #define TEST_REQUEST ("GET /posts/1/ HTTP/1.1\r\nHost:jsonplaceholder.typicode.com:80\r\nContent-Length:0\r\n\r\n") char aux_str [100]; int8_t answer; int aux = 0; int data_size = 0; #define HOST_NAME ("jsonplaceholder.typicode.com") #define HOST_PORT (80) void setup() { // init sequence Serial.begin(UnoBaudRate); gsmSerial.begin(UnoBaudRate); gsm_power_on(); while( (sendATcommand(AT_CREG_QUERY, "+CREG: 0,1", 500) || sendATcommand(AT_CREG_QUERY, "+CREG: 0,5", 500)) == 0 ); Serial.println(F("GSM : Registered to network")); Serial.println(F("GSM : Ready for AT command")); } void loop () { sprintf(aux_str, AT_CHTTPACT_COMMAND, HOST_NAME, HOST_PORT); Serial.println(F("\n*** Start HTTP Transaction ***\n")); Serial.println(AT_CHTTPACT_INIT_RESPONSE); answer = sendATcommand(aux_str, AT_CHTTPACT_INIT_RESPONSE, 60000); Serial.println(aux_str); if (answer == 1) { data_size = 0; Serial.println(F("Sends Request:")); Serial.println(TEST_REQUEST); gsmSerial.println(TEST_REQUEST); // Sends aux_str[0] = ESC; aux_str[1] = 0x00; answer = sendATcommand(aux_str, AT_CHTTPACT_DATA_RESPONSE, 300000); if(answer == 1) { Serial.println(AT_CHTTPACT_DATA_RESPONSE); while(gsmSerial.available() > 0) { Serial.print((char)gsmSerial.read()); } } Serial.println(F("\n*** End HTTP Transaction ***\n")); Serial.print(F("Memory Free : ")); Serial.println(memoryFree()); while(1); // halt } } // variables created by the build process when compiling the sketch extern int __bss_end; extern void *__brkval; // function to return the amount of free RAM int memoryFree(){ int freeValue; if((int)__brkval == 0) freeValue = ((int)&freeValue) - ((int)&__bss_end); else freeValue = ((int)&freeValue) - ((int)__brkval); return freeValue; } void gsm_power_on(){ uint8_t answer=0; // checks if the module is started answer = sendATcommand("AT", "OK", 2000); if (answer == 0) { // power on pulse digitalWrite(powerGSMPin,HIGH); delay(200); digitalWrite(powerGSMPin,LOW); delay(6000); // waits for an answer from the module while(answer == 0){ // Send AT every two seconds and wait for the answer answer = sendATcommand("AT", OK, 2000); } } } int8_t sendATcommand(char* ATcommand, char* expected_answer1, unsigned int timeout) { uint8_t x=0, answer=0; char response[100]; unsigned long previous; memset(response, EOS, 100); // Initialize the string delay(100); while( gsmSerial.available() > 0) gsmSerial.read(); // Clean the input buffer gsmSerial.println(ATcommand); // Send the AT command x = 0; previous = millis(); // this loop waits for the answer do{ if(gsmSerial.available() != 0){ response[x] = gsmSerial.read(); x++; // check if the desired answer is in the response of the module if (strstr(response, expected_answer1) != NULL) { answer = 1; } } // Waits for the asnwer with time out } while((answer == 0) && ((millis() - previous) < timeout)); return answer; } int8_t sendATcommand2(char* ATcommand, char* expected_answer1, char* expected_answer2, unsigned int timeout) { uint8_t x=0, answer=0; char response[100]; unsigned long previous; memset(response, EOS, 100); // Initialize the string delay(100); while( gsmSerial.available() > 0) gsmSerial.read(); // Clean the input buffer Serial.println(ATcommand); // Send the AT command x = 0; previous = millis(); // this loop waits for the answer do{ if(gsmSerial.available() != 0){ response[x] = gsmSerial.read(); x++; // check if the desired answer is in the response of the module if (strstr(response, expected_answer1) != NULL) { answer = 1; } // check if the desired answer is in the response of the module if (strstr(response, expected_answer2) != NULL) { answer = 2; } } // Waits for the asnwer with time out } while((answer == 0) && ((millis() - previous) < timeout)); return answer; }
