Architecture level Optimization for ASIC
jayakumarjay
Junior Member level 3
Can anyone tell the best architectures for the basic elements like adder ,
accumulator, multiplier.
i found that wallace tree multiplier is the best multiplier architecture
anyone can comment on it
eda_wiz
Advanced Member level 2
it depends upon your area/timing requirements ..
for low area .. ripple carry adder
for better timing . carry lookahead adder..
someother adders (like csa)are also available in DW .. DC will choose according to your constraint reauirements.
About Multiplier ..Wallace tree arch is good for high timing requirements... but the total area is high due to lots of CSA adders....
I recently designed a multiplier which is combination of Radix4 and Wallace tree..
c this paper..
Radix4 booth recoding reduces the number of partial products .. while CSA adders helps in keep the timing..
negreponte
Member level 4
a good site for computer arithmetic
linuxluo
Full Member level 6
hi,
a book name "low power cmos design" maybe helpful for you.
negreponte
Member level 4
Computer organization & Design the hardware/software interface
by David A. Patterson, John L. Hennessy
eexuke
Full Member level 4
Every existing architecture has its own advantages and disadvantages. When you are choosing among different architectures, you should consider about the following:
1)timing(maximum frequency)
2)area(related to your die size and costs)
3)power
4)the back-end deisgn for a certain architecture
So,I am afraid there is no "best" architecture in ASIC design.It just depends on your spec and requirements
sxqzj
Member level 4
i am agree with eexuke!
Aser
Member level 5
The best architecture is that
that is used in the module library
which is provided by this or that technology.
That modules are specially optimized for speed or power on demand.
And the customer will try a lot of efforts to achieve similar results.
troops
Member level 3
don't worry , as u synthesis , u can select which kind perform u wanted ... the tool work well
