Anyone used FTDI FT232BM with PIC before?
ericmar
Full Member level 5
Singapore
3v ftdi serial
Hi all, hv anyone of u tried this chip before? Do I need to use a MAXIM 232 chip in between of this chip and PIC?
pisoiu
Advanced Member level 3
Romania
No, you don't. Max 232 is required to convert serial signals from uC (which are 0-5V or 0-3V) to +/- 15V required by RS232 interface (PC DB9 or DB25 connector for example). In your case, you have to connect the VCCIO pin from FT232 (which is the power pin for serial inputs/outputs) to the power supply of PIC, then connect directly all the signals you need.
/pisoiu
ericmar
Full Member level 5
Singapore
/pisoiu
Why do I have to connect the VCCIO pin from FT232 to the power supply of PIC? I have an external power for the PIC itself.
pisoiu
Romania
VCCIO is powered with the power supply of the circuit interfaced with the datalines of FT232. The power supply of FT232 must be 5V, therefore you will connect it to 5V from USB or from external power supply. But the circuit wired to datalines can work on diffrent voltage (ex. 3,3V). If the interfaced circuit works on 5V, then put 5V on VCCIO. If the external circuit works on 3,3V, then put 3,3 on VCCIO.
/pisoiu
Edited: The FTDI site contains application schematics with interfaces to various microcontrollers, take a look there.
ericmar
Full Member level 5
Singapore
manu said:
Have a glance here : ;)
h**p://164.15.88.56/
regards,
Thanks but I dont know France!!!
Most of the posts in the forum are in France.
Cluricaun
Advanced Member level 2
Hi
You can translate by using altavista. The English is not perfect but understandable.
Cl
manu
Full Member level 3
France
regards,
look the projetcs of the webmaster, they're available in french and english :wink:
regards,
angeliz
Newbie level 2
hello
y use USBMOD3 of ELEXOL, its so easy to send data to the USART of the pic 16F876 (MFC Dlpvcc2 dll FTD2XX )
bye (Angeliz french)
ericmar
Full Member level 5
Singapore
SphinX said:
Salam,
h**p://www.voti.nl/usb-1/index.html
Bye
Salam,
Yes! I'm using this! But the problem is I dunno where to start and how to combine this with PIC!!!
manu
Full Member level 3
France
ericmar said:
SphinX said:
Salam,
Bye
Salam,
Use the serial module of your PIC :?
dpsman
Member level 5
I´ve tasted FTDI chips up to 1MBps in XP,WIN98, and WINME. Results: A GREAT and CHEAP chip. I´ve followed application notes from FTDI website, they are really cookbooks.
