kushal.khanal
Newbie level 6
Hi again guys n gals!!!
As shown in attachment below,
what the problem is input to opamp is 6-8v DC which is first case;
now since opamp is used as a comparator, it gives 4-5V output,which is desired;
BUT, even when input to the comparator is 200-300 mV still output is 4-5V.
Now, the more interesting fact is that if I supply the comparator 6-8v DC from a separate voltage source, comparator gives 4-5V output which again is desired.
Now,when input to the comparator is 200-300 mV from a separate voltage source, output is of the order of 200-400 mV,which is absolutely correct.
But, obviously I can't take 6-8V input from a separate voltage source(I have to use the 6-8V DC generated within my circuit.
Is it the current that is playing underground role??????
But since I have used 7809 voltage regulator as supply and there is only one IC before this stage;So I don't think current is the cause.
So what should I do??????????
Any similar experiences??????
Regards,
Kushal Khanal
Regards,
Kushal Khanal
