Anyone knows what connector should be used for this LCD module (Photo attached)
madokaaukawa
Newbie level 6
Toronto
I did search on Digikey. ribbon cable, flat cable connectors. I have no luck to find the right connector for this LCD module.
The pitch for the cable is 0.5mm. By looking at the module, it looks like need some connector can allow cable plug into it and solder other end to PCB.
What kind of connector I should look for? Please guide me
Thanks in advance
sky_123
Known as flat flex connectors (FFC), Molex make some sockets for them (the sockets are surface mount).
0.5mm is a standard pitch for them. Just make sure you get one with the contacts on the upper or
lower surface, to match the LCD, depending on if you intend to fold over the flat flex or not.
Otherwise, you may need to plug the LCD in face-side down!
Digikey, Farnell, and others sell these types of connectors.
