WalkingBeijing
Newbie level 5
icl7106 power supply
My ICL7106 based LCD voltage-meter has 1 count jitter problem.
This meter is mounted inside a bentchtop DC 30V/3A power supply and is used to measure the output voltage of this power supply. The actual output of this power supply is stable and this problem is from the voltage-meter. This linear style bentchtop power supply has a hulking transformer. And this power supply has a closed METAL housing that have connection to the 'Protective Earth'.
But when I connect the 'output Negative' and the 'PE', display will turn very stable....
Anyone could give me some advices.
thanks....
thanks....
