We calculated that a 620 ohm resistor in series with two 3.3V blue LEDs and a 12V supply will limit the current to only 8.7mA. The current with the switch turned on will be exactly the same as the peak current when the sound is loud enough to completely turn on the transistor (which is also a switch). But since the transistor rectifies the sound signal then the average current when loud music plays is half which is only 4.4mA.when is switch in the 2nd position when LEDs needs to be turned on allways, will then be maybe some problem cause then the current will go through the LEDs from + to - how much as i know the correct is from - to + so this will be indirect current through the LEDs..will it be a problem or it will work well??
