Any trick to make a linear regulator go down to 3.3V instead of the ref voltage?
xReM1x
Member level 5
hi, for my current sink I use a ref voltage that turns on from the linear supply, the problem is the ref voltage is 3.3V and unfourmently the regulator goes down to 1.2V~ and I need the regulator to go down only to 3.3V~. not less. the regulator is LT1083. I know I could drive a voltage to the adj pin but maybe there is easier way? thanks.
LT1083/4/5 all use Vref =1.250V , so Vo.min=Vref.
If you want to regulate to 0V, you would need a V->=-1.25 to drive Vadj. Low current but stable voltage.
No problem?
No problem?
But I need it so it will go down to 3.3V and not 0V. also isnt there other options without other -1.25V?
Instead of a voltage regulator maybe you could use an opamp.
To check on this we need more data, like current and schematic...
Klaus
hi, for my current sink I use a ref voltage that turns on from the linear supply...
Do you use it as a current regulator (so you do not care about the voltage), or a voltage regulator?
Sorry but I did not understand exactly what you would like to do.
If you would like an adjustable voltage regulator that goes from 3,3 and up, then you should use a constant resistor in series with the trimmer resistor. This will limit the bottom limit of output voltage.
