any software for checking two version of pcb file ?
omid_juve
Full Member level 1
do we have any software for checking two version of pcb file ?
Not sure to understand clearly the question.
I always visually check my generated Gerber and Exellon files with the free demo of GC Preview. Quite basic, but you directly see if it looks normal or not and it allowed me to prevent some stupid mistakes. You can download it on https://www.graphicode.com/ .
Regards,
Loïc
you mean 274-X format and 274-D format???
could not understand fully
Added after 2 minutes:
PCB Partner can check 274-X format only.You can have a try:www.pcbpartner.com
let me make it clear , we have two version of one pcb that all the differences that they might have is the place or kind of 2 or 3 component and also some new nets might be added i want a software that show these differences .
thanks
hi,
you could just design compare the two files if they are from the same tool and it will generate an ECO report where you could find all the changes.
Regards,
Ricky
I never used it, but there is a tool to compare two gerber files:
i use altium designer 6.8 please tell me how i can do this
IN CAM350 ,u can compare two gerber layers,It will show u the differences
    omid_juve
mashak said:
Use DOCTAR design compare software. Its really good
I will second the comment on DOCTAR. We bought the software so we could see the differences on testpoints between versions of PCBs, but we keep finding new and useful ways to use this tool. It is well worth the price we paid for the tool! You can get more information about the tool here: http://www.cadalist-enterprises.com/applications/doctar/index.htm
You can check final gerber data with cam tools, also you are possible to use campare function in EDA tool if it is ready in your EDA tool(this function is available in CR5000 tool), otherwise please check your design eco.
