Element7k said:I saw the new features described on recent issue of Microwave Journal.
Cheers,
Element7k
eirp said:Dear Element7k!
Please post the paper here, as I'm also very interested!!
TNX,
Eirp
Chinasky said:Scanning MJ issues, I cannot find any news about CST MStudio 5. In the News Products section of the 9/2003 issue you can read
---------------------From MJ---------------------------------
This service release of CST Microwave Studio ® (CST MWS) and CST DESIGN STUDIO™ (CST DS) includes several new functionalities since the release of version 4.0. The most significant features include: numerous improvements in the calculation of farfields including Ludwig Transformations, nearfield calculations, time domain probes, phase plots and phase centre calculations. Modal waveguide ports can be defined inside the calculation domain. The new general voxel import allows engineers to input or create their own models for SAR calculations in addition to using the commercially available anatomical data set "HUGO." Enhanced post-processing capabilities include new automatic schemes enabling easy, versatile evaluation of parameter studies, field integration over arbitrary faces, and the application of the AR filter to probe signals, implementation of a direct, multi-frontal frequency domain solver with fast frequency sweep, improved periodic boundary conditions in the frequency domain and improved 2D and 3D import options.
---------------------End-------------------------------------
But no mention to the "service release" they are talking about. I think they must be talking about 5.0 because in the 6/2003 issue they announce 4.2 release
---------------------From MJ----------------------------------
The latest release of Microwave Studio ® version 4.2 provides new functionality in its service packs. These functionalities include: numerous improvements in the calculation of farfields, including Ludwig Transformations and Time Domain probes for antenna designers; model waveguide ports that can be defined inside the calculation domain; new general Voxel import that allows engineers to input or create their own models for SAR calculations in addition to using the commercially available Anatomical Data Set "HUGO"; and a new automatic post-processing scheme to enable easy, versatile evaluation of parameter studies.
------------------------End----------------------------------
As usual, their web page says nothing :-(
CST’s user group meeting offers users of CST MWS & CST DS:
• An in-depth preview and demonstration of CST MWS v5 and CST DS v3
• Tips on the advanced use of CST MWS & CST DS
• Presentation and discussion of interesting application examples
• This session will conclude with a discussion lead by Managing Directors
Dr. Bernhard Wagner and Dr. Peter Thoma
CST MICROWAVE STUDIO® - HF Design and Optimisation
This eagerly awaited major new release of the successful 3D electromagnetic
simulation software CST MICROWAVE STUDIO® (CST MWS), promises to
benefit design engineers over the whole application range. CST MWS will again
increase design accuracy and efficiency by introducing cutting edge simulation
technology. The 1300 functional changes, implemented since the release of
version 4, result in a noticeable cut in simulation time.
CST MWS is fully embedded in the open CST design environment (with CST DS)
and can be tightly integrated with any other compliant software through the COM
interface.
CST DESIGN STUDIO™ - HF Synthesis and Optimisation
CST DS is central to CST’s open design environment, allowing optimisation of
electromagnetic components over and beyond the boarders of vendors and
methods. New in CST DS version 3 is a tight link with APLAC’s Circuit Simulation
and Design Tool and system simulation tools allowing efficient co-simulation and
optimization at all simulation levels.
Customers and advanced testers of CST MWS & CST DS are
invited to participate in CST’s Update Road Show 2003.
plasma said:Hi
CST5.0 will be out Jan,2004. said the salesman.
the big advantage in VER. 5 is the Mesh on demand
along the structure you can change the mesh to make
refinement where it's needed and large cell where it's not needed
in example that I saw of helix antenna in the ver.4.3 was 1.5milion cells
in ver.5 200.000 cells so now you can gain in time or move to big
structure. for now the mesh manually in the next year it will be
automatically
also the Design Studio Second program that workes with Microwave Studio help to save time in big structure try it and then you will see
the benefit of working with both Programs.
RGZ
PLASMA
