Hi guys,
Dealing with a WG circulator.....
I used Uniform magnetic bias before for the ferrites in HFss and got good results. However, in order to get more realistic results and understand exactly how strong the magnetic bias needed to saturate the ferrites, I am trying to use maxwell to generate a "real" magnet bias enviroment (2 permanent magnets and 1 magnetic return), and import this enviroment to my hfss circulator model.
Thus, according to the circulator's postion and dimensions, I built the maxwell model (2 magents, 1 magnetic return, and 2 ferrites between magnets) and could see the magnetic flux density (B) in the ferrites. Then I saved this maxwell files in the same folder of hfss circulator file.
However, when I tried to import this maxwell files in hfss model by selecting "Non-uniform magnetic bias", hfss gave me the following error:
[error] Adaptive solution setup, process hf3d error: Error in creating static solutions from Maxwell.. -- Simulating on machine: hfss1 (2:37 PM Dec 01, 2009)
Does anyone know what is this problem and how to solve it?
Thanks in advance.
