tomas
Member level 1
- Joined
- Dec 16, 2012
- Messages
- 41
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,553
Hi I have done PCB and soldered all components. PCB:
All things working fine, signal is transmitting, and receiver part receives signal correctly. But the problem is DISTANCE... It works only in 10 cm range.. I need 10 meters minimum..
Transmitter and receiver I use: https://www.abacom-tech.com/assets/data_sheets/RTF_L-DATA-SAWuser.pdf
For antennas I'm using 17 cm wire rod (made it by myself from simple wire. I just removed isolation from wire)
Any suggestions?
Any suggestions?
