Antenna model for ADS
sbhalerao
Member level 1
Hello,
I am doing a simulation using ADS involving conversion of Rf to DC power..
I need to model a antenna.. I could do with a simple lumped parameter model of a antenna.. . I need to maximise the voltage output from the antenna, which i will later convert to DC using a rectifier... I need to do proper impedance matching as well as adjsuting Q.. I could do with very high voltage,but low current values....
Could anyone of you give a antenna model (simple R-L-C model) that could be used for 2.4 GHz and would yet be simple.. i want to simulate using ADS...
Thanking you in advance...
Shantanu...
