[Antenna][Drawing tip requested] Stacking 2 spiral inductors for enhacing inductance
chromatik
Member level 4
Switzerland
I am just asking myself if it is possible to stack 2 planar circular spiral inductors, with respect of the current direction, and with the minimum overlay.
If I start from the outside of the first coil to the center, and switch from this first coil to the other, the current flows the opposite direction, so I guess the inductor will suffer for this problem?
Do you have some advices ?
Thanks for your help
Regards
Chromatic
Draw the inductor so that turns on both layers follow the same direction.
hi
i think this work not useful for antenna dont try it
thats true it can work for narrow band application but it too expensive for RFID
