Antenna array from a single element???
alokatzenith
Newbie level 6
Hi !!
I have to build an array of patch antenna (2*16). I have a single patch antenna but i dont know how to build such a large structure. I m using IE3D for this purpose. Is there any command in IE3D by which I will get complete array or I have to each and every element manually. Since manually placing elemnts with precision is very difficult so I want to avoid it.
Plz tell me the solution to my prblm.
You can see the help manual in the IE3D. There are the examples in detail like the problem your described.
There is a section in the user's manual illustrating how you start from one element, divider and how you can copy and paste to create the array.
