Zynthos
Newbie level 1
Hello. I have an array of antennas and I would like to model the effect of phase shift between each antenna in the array on the gain pattern and power output. I have looked through the HFSS Help and the best way I have found is to "Edit Sources" and manually change the phase of the port feeding each antenna for every simulation. This is very tedious and I was wondering if there was a way to sweep these phase parameters or some easier way to accomplish this is general.
Thank you!
Thank you!
