mstripman
Junior Member level 1
Hi All,
Iam using Ansoft Designer SV for MSA simulation. I have observed that the output depends to quite an extent on the parameter "lamba refinement factor". However the problem is that if I take this value high enough the no. of inknowns increase significantly exceeding the limit of 300 for SV. So can you tell me how to determine the optimim value of this parameter so as to give reasinably accurate answer and also to not increase the no. of unknwons significantly.
Thanks in advance.
Sincerely
mstripman
Thanks in advance.
Sincerely
mstripman
