how is reception done in an 8051 uc???...do we have to keep on resetting a continuosly transmting transmitter for the sequence to get received on the receiver????
its acually being sent over a 433mhz tx rx pair str 433...but the problem is that the sequence is not gattin received unless we press the reset switch on the transmitter...isnt it supposed to be asynchrinously receiving the sent info???...that means that as soon as it comes in the range of the transmitter it should start receiving the bits isnt it???but we need to continously pressing the reset button for it to work even if in range...plzz help
yes it should recieve without pressing reset..
I have used this pair with Encoder and Decoder HT12E &HT12D respectively...Connect an extrenal Single strand wire as antenna and check may due to antenna it is not working.. check once.. otherwise check by givening VCC and Gnd to Tx and Connect the RX output to LED s and check...
