Another nice LCD menu library
picnoobie
Full Member level 1
lcd menu library
Can't remember where I got this one, I think from avrfreaks.net, else
I'd just post the link.
I've tried it with pic, it's easy to use.
Won't works with CCS compiler tho, function pointer not supported I think.
..have fun
tinymenu c30
Tinymenu is very nice and works perfectly with C30.
For the CCS compiler I could only manage to write a state machine. It is big, ugly but works.
Did anyone managed to write an efficient menu system for CCS?
Really cool code! I have been trying to compile using HI-Tech C 9.80 on MPLAB and almost there though the following declaration will not compile (compiler wants a right parenthesis after "*entry" which of course would keep out the proper number of variables :shock::
static void menu_print_entry(menu_entry_t *entry,
int max_width,
int selected )
This ties to the TYPEDEF:
typedef struct menu_entry_s {
int flags; // see flag definitions above
void (*select)(void *arg, char *name); // routine to call when selected
char name[MENU_ENTRY_NAMELEN]; // name to display for this entry
void *value; // value to pass to select function
} menu_entry_t;
Any clues on the problem here?
Thanks,
Pete
