ghattasak
Member level 1
- Joined
- Dec 31, 2012
- Messages
- 33
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,595
Code Java - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 import java.util.ArrayList; import java.util.List; import android.os.Bundle; import android.provider.ContactsContract; import android.provider.ContactsContract.PhoneLookup; import android.app.Activity; import android.app.ListActivity; import android.content.Context; import android.database.Cursor; import android.util.Log; import android.view.LayoutInflater; import android.view.Menu; import android.view.View; import android.view.ViewGroup; import android.view.View.OnClickListener; import android.widget.ArrayAdapter; import android.widget.ImageView; import android.widget.TextView; import android.widget.ToggleButton; public class Main extends ListActivity implements OnClickListener { @Override protected void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.contact_view); final String [] MyName = new String [10]; final int i=0; Cursor people = getContentResolver().query(ContactsContract.Contacts.CONTENT_URI, null, null, null, null); while (people.moveToNext()){ int NameIndex = people.getColumnIndex(PhoneLookup.DISPLAY_NAME); String Name = people.getString(NameIndex); MyName[i] = Name.toString(); i++; } setListAdapter(new MyAdapter<String>(this, android.R.layout.simple_list_item_1, R.id.textView1, MyName)); } class MyAdapter extends ArrayAdapter<String>{ public MyAdapter(Context context, int resource, int textViewResourceId, String[] string) { super(context, resource, textViewResourceId, string); // TODO Auto-generated constructor stub } @Override public View getView(int i, View convertView, ViewGroup parent) { LayoutInflater inflater = (LayoutInflater) getSystemService(Context.LAYOUT_INFLATER_SERVICE); View row = inflater.inflate(R.layout.contact_view, parent,false); ImageView iv = (ImageView) row.findViewById(R.id.imageView1); TextView tv = (TextView) row.findViewById(R.id.textView1); ToggleButton tb = (ToggleButton) row.findViewById(R.id.toggleButton1); tv.setText(MyName[i]); return row; } }
hello i am having trouble working with this i am a beginner in android and java i want to pull out contact name information and place them inside a string array MyName then use the inflater to map each contact name to a textfield in the xml file i also have a toggle button and an image that i would like to use separately for each row how can i do that? and how can i fix this code where the at the class MyAdapter is not accessible and is stating that it is undeclared and the setListAdapter creationg function is showing an error
Multiple markers at this line
The type Main.MyAdapter is not generic; it cannot be parameterized with arguments <String>
