sab_sab
Newbie level 6
I am collecting data into two folders. One of these folders contains 60 excel files with vibration test data from the motor when new bearings were installed. These 60 files were collected over a period of one day and have time stamps. The other of these two folders has ~1000 excel files for two months worth of data from the motor with different loads applied to it. The folder with data collected using new bearings will be used to form a baseline. The other folder's contents will be used as test data. I will conduct data analysis that includes signal processing and prediction for fault detection. I am in the first phase now and need to extract features from the vibration data in order to establish trends. For that, I am doing FFT analysis and my question is this: When I plot power vs. frequency for the FFT analysis of the first file in the first folder, I see the peaks. I then plotted the power vs. frequency plots for the remaining 59 excel files on the same graph (overwriting them). Is this a correct way of looking at/presenting the data? Does anyone have an suggestions on how to identify trends or how to extract features? I am a bit lost here and any help would be greatly appreciated.
