Analysing Rectifier input and output waveforms
saonibanerji
Newbie level 6
Newbie level 6
Singapore
Analyzing Rectifier input and output waveforms
Hi Guys,
I am simulating a cross- coupled rectifier and need help in analyzing the input and output rectifier waveforms for correcting the circuit.
Need Help!!
Thanks,:smile:
I don't understand your circuit. You have the signal going to the MOSFET gates but nowhere else. How do you expect a signal on the output?
The output voltage waveforms should be that of an ideal full wave rectifier. But It is not so ( illustrated in the third snapshot) I need to analyse and correct the circuit specifications accordingly to receive the correct output waveforms
I added coupling capacitors and the output voltage is regulated now. However the PCE is very low. Could anyone suggest me an idea to increase the PCE?
