Analog Voice Over VPN??
ahmed osama
Full Member level 6
Cairo, Egypt, Egypt
voice analog over vpn
About
Analog Voice Over VPN?? using cisco routers
What I should takecare & how to ensure good Voice comm. Quality?
What the min. bitrate for one voice conversation?
at last does there is a diff between
"VIRTUAL TUNNEL INTERFACE WITH IP SECURITY" & the VPN
or it is the same
Also what is the diff between the Network Module & Interface??
Salam,
-to achieve this you should have an IP telephone system (VOIP).......install a VPN and VOIP clients on the host and then you can create a VPN tunnel to your VOIP server by VPN gateway....the host now can make any voice call......If you are talking about site to site voice calls you should install a VPN gateways in both sides.
-it depends on the compression rate you specify in your VOIP system
-there is no difference
-I think network module containing many interfaces....which usually installed in large multi-layer switch such as cisco 4000 series.
Best Regards,
