Analog to digital converter - further info (pls help)
simonmada
Newbie level 6
Newbie level 6
Hi everyone,
I'm undertaking a project involving Analog to Digital Converter (ADC). From what i know, one way to implement this ADC in Verilog is by using a DAC and comparator. Basically this method is based on the Successive Approximation. The problem with this design is that it is slow as it requires many comparisons. Is there any ADC with parallel(flash) comparisons where we can speed up the design?
The application note is Xilinx app155. What I want to know is that is there any other methods to implement the ADC in Verilog? Any further info on the different types, block diagrams, and how they work for ADCs are very much appreciated.
Thank you in advance.
you means to implement a sigma-delta ADC, but can you tell me how this ADC receive analog input ?
and maybe verilog_AMS is anohter option.
BR.
ls000rhb
Re: Analog to digital converter - further info
The analog input will be the input of the comparator. Therefore the comparator would have two inputs. One is the analog input, the other would be the output from DAC.
