muntahajameel
Newbie level 3
- Joined
- Nov 24, 2014
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 42
I am having difficulties with having both analog input and digital output on the same port on PIC16F88.
On PIC16F88, PORTA is bidirectional I/O pins can be used for both analog inputs or digital inputs. I would like to have; RA1/AN1 as analog input and RA0/AN0 as digital output which will be connected to an LED.
it works with RA1/AN1 by configuring :
TRISA = 0x02; // set AN1 pin as input
ANSEL = 0x02; // set AN1 pin as analog
i connected a temperature sensor with RA1/AN1 and i have received the data correctly.
to configuring RA0/AN0 as digital output as:
ANSEL = 0X00; //configure AN0 pin as digital
TRISA = 0X00; //configure AN0 pin as an output pin
with that configuring the data revived from the sensor was in correct why?
is that configure was correct?
this is the program code :
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 float temp_res=0; float temp; const unsigned short VREF = 4.75; char address; char txt[4]; char FanStatus=0x66; // fals(f)=0x66 void main() { ANSEL = 0x02; //Configure AN1 pin as analog TRISA = 0x02; //Configure AN1 pin as input ANSEL = 0X00; //configure AN0 pin as digital TRISA = 0X00; //configure AN0 pin as an output pin TRISB = 0; //configure POrt B as an output port PORTB=0; ADC_Init(); //Initialize the ADC UART1_Init(9600); //Initialize the UART with 9600Kbps Baud Rate Delay_ms(100); // Wait for UART module to stabilize PORTA.f0 = 0; // FAN initially OFF while(1){ temp_res = ADC_Get_Sample(1); //Get temp readings from ADC module temp = (temp_res * VREF)/10.240; floatToStr(temp, txt); /* temp_res = ADC_Get_Sample(1); //Get temp readings from ADC module temp = (temp_res * VREF)/10.240; floatToStr(temp, txt); if (UART1_Tx_Idle()==1) { UART1_Write_Text("y"); UART1_Write_Text(txt); UART1_Write_Text("end"); } */ if (UART1_Tx_Idle()==1) // end if idel { UART1_Write_Text("z"); UART1_Write(FanStatus); UART1_Write_Text(txt); UART1_Write_Text("end"); } // PORTA.f0 = 0; // FAN initially OFF if (UART1_Data_Ready()==1) //If data is received { address=UART1_Read(); // read the address if(address==(0x63)) //if the address=m means turn on { PORTA.f0 = 1; FanStatus=0x74; // true } else if (address==(0x64)) //if the address=n means turn off { PORTA.f0 = 0; FanStatus=0x66; } } // end if ready delay_ms(10000); } // end while } //end main
