analog circuit generating powers of a value
preethi19
Full Member level 5
Hi is there any analog cmos circuit that generates say 2 to the power of... Or like 3 to the power of any value. Not looking for a squarer but like to use any independent power value. not looking for exponential function either. Like something generating 4^5.... Its like i should be able to choose any base value and have it fixed say for eg 4 and vary the exponent from certain range.. Pls help.. Thank you!!!
If you wanted 1/e to the power of x... then you can use the capacitor discharge curve. Or rather, a mirror image of it.
The capacitor discharge curve is time related. Vnow= Vstart x (1/e)^t.
This probably does not suit your purpose.
Or possibly a diode junction response. There may be a portion of the diode curve (V versus A), that resembles what you are looking for.
However I once tried to match my real data to an equation, and the best I could find was A= (V x 1.25) ^ 20. It is not the type of equation you want. Mine is a y=x^20 type equation.
You are looking for y=2^x, or y=3^x.
Probably a single circuit by itself will not do it. But several cascaded circuits would. Like Log-Multiplier-Antilog.
That is how analog computers worked.
