spbhu
Member level 2
A very interesting problem, for compensation of a 2-stage opamp, we normlly use miller capacitor to do pole splitting, and a nulling resistor is ususlly used to cancel the RHP zero, and sometimes even to cancel the non-dominant pole.
How large the resistor should be ? The book by Johns Martin mentioned that, normally it can be selected such that the LHP zero [1/(Rnull -1/gm)Cm] locates at about 1.2 times the unity gain frequency of the op-amp before nulling resistor is used? What's the reason behind this, why donot we move it to even lower frequency? I believe it is not just because of the area of the resistor.
Anybody can explain this? Thanks very much....
