I tried to program with winPic800 a PIC12F683 but i forgot, before programming, to read the empty chip and sign the value of the last 2 bytes (oscillator).
Now when i try to program the pic i get errors during verifycation at different address.
Hi. The last two bytes you do not need to program for the chip to work. You only have a 4 MHz internal RC osc which is having a large error of some 5 - 10%. your programming error is due to some other error ! Check if your programming voltage is OK also MCLR !.
Added after 3 minutes:
i use **broken link removed** and according to its **broken link removed** and to the **broken link removed**, SW2 (SW1-1) must be closed, right?
I have to program the pic with a code that allows to run backup games on nintendo wii and a tutorial (made for 12f629) says to backup the last 2 byte and to insert them in the new code before programmig the pic.
