Amplifier design using PD85004 LDMOS
adnan012
Advanced Member level 1
I am trying to design a broad band amplifier ( 300MHz-500MHz) using PD85004.
The required output power is less than 1 watt.
PD85004 ADS model is available.
How can i start the design using ADS? What are the appropriate steps? I want to follow the following Phillips Application Notes in designing the amplifier and matching networks.
"A wideband power amplifier (25 − 110 MHz) with the MOS transistor BLF245" and
"RF transmitting transistor and power amplifier fundamentals"
I have already simulated the demo board.
The problem i am facing is that in Philips application note "A wideband power amplifier (25 − 110 MHz) with the MOS transistor BLF245" the mos output is represented by the output capacitance with a resistor in parallel. They calculated the resistor value by using Rl=(v^2)/2*Pout. For my design it becomes
Rl= (13.6)^2/2*1=92.48 ohm . Next the output filter is designed by by using the rc combination. My question is that, how can i simulate it in ADS. How load resistance Rl is realized in ADS?
