Amplifier biasing: Methodology?
megaknaller
Member level 2
Member level 2
I´m working with Virtuoso/Spectre in the design of a low noise amplifier. The very first thing to choose is a proper transistor operating point which provides a good compromise between noise figure (low current) and high gain (high current). I´ve been told that the first thing is to define the appropriate current density (J_c) for the required noise figure but I don´t have the technology minimum noise figure specifications nor its corresponding optimum biasing.
How can I do this? Should I set a minimum transistor size and perform a sweep over different collector currents (I_c) for obtaining different J_c and look at the noise figure/maximum available gain results to decide which current to choose? Or how do you evaluate the right J_c for your application?
