Am looking for a 430 MHz 1 W amp ic?
biff44
Advanced Member level 6
New England, USA
430 MHz 1 W amp ic?
Am looking for an amplifier IC with approx the following parameters. Having trouble finding one:
Gain: 20 dB min
P1db: +28 dBm min, prefer +30
DC Voltage: 3.3 V
Freq: 430 MHz
Unconditionally stable
Any ideas?
Re: 430 MHz 1 W amp ic?
Check this:
Maybe can help you
430 MHz 1 W amp ic?
The critical part is the supply voltage.
Is it possible to operate at higher potential?
Added after 10 minutes:
I think AM52-0024 or MAAPSS0095 or should be ok.
Check the design for low frequency as they are not
430 MHz 1 W amp ic?
No, it must run off of a lithium battery. I know there are plenty of 5V parts out there. I know RFMD has at least one (RF2192), and NEC has some discretes that might do the job. But I am still looking for more options.
