Hawaslsh
Full Member level 3
- Joined
- Mar 13, 2015
- Messages
- 164
- Helped
- 5
- Reputation
- 10
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Washington DC, USA
- Activity points
- 3,422
Hello all,
I am using Altium designer and I am routing a 4 layer board for the first time. I have run into an issue using vias during interactive routing. I will be routing a line on the bottom side (layer 4) and want to move to the topside (layer 1) using a via. During interactive routing I will hold down shift and control and scroll the center mouse wheel to change layers. When i intended to put a through via, Altium will instead place two blind vias, one from layer 4 to layer 2, and a second from layer 2 to layer 1. Is this normal? Should i have changed something in my design rules?
Bonus question: I am routing some RF lines on the top layer. The PCB fab house tells me the upper pre-preg layer will be 110um thick and give me an er = 4.29, so I could use microstrip or co-planar waveguide and stay within the cheapest fabrication tolerance, 6mil lines and spaces to create 50 ohm lines. Most RF eval boards I see use co-planar waveguide, but on a 4 layer board this would require blind bias (from the top layer to an inner ground plane) in order to create my RF shielding and ensure the top layer ground plane and inner ground plane are connected. I hear using blind vias increase my price. In general is that price increase proportional to the number of blind vias, or somewhat a fixed added cost? I could microstrip lines to avoid using A LOT of blind vias, but most of the analog chips will need blind vias regardless to be grounded to the inner layer. Is there a larger benefit to using CPW over microstrip that would make the added costs worth it?
Happy to provide more context,
Thanks in advance,
Sami
Thanks in advance,
Sami
