Altium PCB Component pads
redlink
Newbie level 3
Anyone knows if is possible on PCB remove unused component pad? In the schematic is possible hide the pin and its attributes, but is possible do the same thing on the PCB?
Thanks.
if there is a component and you want to remove some pads there are several ways:
1)go to schematic library of the component and remove pads you want to remove
2)after double click on pads you want to remove,alter the hole size and X-Y of the pads to zero
3)after double click on pad you can change the net of that pad to NO NET
Thanks that helped me!
Remember you can use find similar object to search for all 'No Net' Pads and then use PCB inspector to change them all at once.
