Altium LiveDesign Evaluation Board: using FPGAs CLK
Lykos1986
Member level 4
FPGA and CLK
Hello again!!!
I have got the Altium LiveDesign Evaluation Board with Spartan 3. The board has got a clock for the FPGA and I think that connects to a general propose pin but I am not sure about that. Can I use it for general CLK in my projects or I have to put an external clock source?
jay_ec_engg
Full Member level 3
India
Re: FPGA and CLK
No big deal...!!! you can use it if its connected to FPGA pin....if its not connected to global clock pin then the clock performacne (max frequency ans swek) may not be as ggod as GCLK pin. Alternative is use buffered clock and use it for all modules..
shankarmit
Full Member level 3
India
Re: FPGA and CLK
No check that pin.. its not general purpose pin..
its global pin.....
See manual....
Use that pin for your clock... and assign you clock port to that pin
Regards
Shankar
    Lykos1986
Lykos1986
Member level 4
Re: FPGA and CLK
Thanks
Now I am using that pin in a PicoBlaze project.
freeinthewind
FPGA and CLK
if u need do high speed design ,u had better connect ur clock to special clock input pin.
