altium gerbers and the gerbv free viewer
buenos
Advanced Member level 3
Sunnyvale, California, USA
gerbv
hi
i have extracted some gerber files from the altium designer, and opened with the opensource gerberviewer program, the GERBV. ( http://gerbv.sourceforge.net/ )
the problem is, if i open a signal layer, some of the via pads are bigger than they really are in the design. actually i have observed that these pads connect to the plane layers, and they have bigger pad diameters on plane layers, but the gerbv shows the pad diameter from the plane on the signal layers. If i open the gerbers with the viewmate, the pads have correct size.
why is it?
cyberrat
In the sewers of the U.K.
@ltium gerbers and the gerbv free viewer
It could be that the apeture is being misread or there is an error converting from imperial to metric (thou/mm) ?
have you tried adjusting the aperture that is in error to the correct size in the Gerber viewer to see the effect?
buenos
hi
i dont really understand.
some pads are bigger, some other pads are not. interestingly those are bigger, which have bigegr pads on other layers. but gerber files should contain only one layer / file. i think
House_Cat
USA
I would just stay away from Gerbv. Viewmate is a solid product from a big company (Pentalogix) and Gerbv is an open-source program with questionable accuracy.
I can tell you from personal experience that you can trust Viewmate. It is used by many fabs in its full paid form (Viewmaster). I've never heard of anyone having a problem with either Viewmate or Viewmaster. Open source programs are works in progress, and can have many odd problems until they've been widely used and tested for several years.
buenos
ok.
the point is, i would like to reuse their opensource code, as a front end in viewing gerber files. i want to try to write my code to that, which would extract spice netlist from the PCB parasitics, for power integrity (later signal integrity too) simulation with an also opensource and free spice program. there is a little chance that i will succed, because i am hardware guy, not a software guy, although i wrote some DOS and DSP related programs in the past.
House_Cat
USA
OK then, back to GerbV. Yes, the Gerber files output from Altium contain only one layer per file, unless you opt to include one of the mechanical layers with every file in the "Layers" tab of the Gerber Setup dialog.
Do you see the abnormal pads when you load only one layer into GerbV? Have you tried loading one layer at a time instead of a batch import?
My guess would be that Gerbv is doing something wrong when building the aperture table that causes apertures to be overwritten or merged in batch imports. Bringing the layers in one at a time would allow you to check for differences in Gerbv behaviour between the two different ways of loading the files.
buenos
yes. i have tried even to copy a single layer file into a separate folder, rename it, then open it. it was still bad.
maybe something anaomaly is already in the gerbers but better programs can compensate it.
House_Cat
USA
Re: @ltium gerbers and the gerbv free viewer
That's unlikely. A Gerber file is a simple ASCII file. If it's RS-274X, there's a Dcode table at the beginning of the file, and the data is listed following that table. If it's RS-274D, it's exactly the same only the Dcodes are defined in a separate aperture file. The plot data is grouped separately under each Dcode in either case.
For what you are seeing, either the data for a given Dcode would have to be split into other Dcode areas, or the Dcode table would have to have two different entries for the same aperture. Nethier of those things could exist in the original file and still read OK into a different CAM editor.
The problem has to be in GerbV itself. The first thing I would do is find out what Dcode Gerbv thinks the wrong sized pads are. Using a text editor, I would then look at that pad in the Gerber file itself. You can locate it by using the X,Y coordinates from Gerbv, and then scanning for one or both coordinates in the text editor under the Dcode that I got from Gerbv. Compare that entry to the others that properly plot.
If you want me to take a look at it, zip up the Gerber layer that is screwed up and PM it to me. I won't try to write code for Gerbv, but maybe I can see what's going wrong.
buenos
ok thanx.
the guys at gerbv fixed it with the new version 2.1, just it wasnt on the website yet.
