Winter2
Newbie level 1
Hello
New to Altium and I've tried searching but its hard to explain in search terms what I want.
I'm making a part, a switch with two LEDS.
The switch has two pins marked C and two pins marked 1 - so you can use either C and either 1 and the switch will work.
Currently in altium it is routing the C's together (electrically fine, but makes it hard to route other paths nearby)
How can I get the autorouter to choose the pin closest to where it wants to go? I've read up on pinswapping but that seems to be for FPGAs.. is that what I'm meant to be doing?
Cheers
Matt
Cheers
Matt
