Altium Designer Clearance Rule
maxascent
Member level 2
England
Hi
I have created a clearance rule between a via and a pad. I have the online drc on but when I move the via too close to the pad it doesnt turn green indicating a violation. Is this the right rule to use?
thanks
maxascent
Member level 2
England
hi
One more question if anyone can help. Is it possible to set up a rule to cover a track clearance in different areas of a design. For instance I want to have a smaller clearance when routing through a bga than when routing over the board.
Thanks
fala
Full Member level 5
Yes! define rooms to enclose your desired parts then define a new clearance rule for that room then make its priority upper than general clearance rule.
SARDTRA
Newbie level 2
Khonkaen Thailand
1.Design
2.Rules....
3.PCB Rules and Constraints Editor
4.Design Rules
5.Electrical
6.Clearance
7.click Right
8.New Clearance
9.You Can Control
9.1Full Quency :key board
InPolygon
9.2Full Quency:key board
IsTrack and IsPad and IsVia
9.3you can set Different Nets Only
30 mil or 50 mil or 10 mil
10.you can select many size Clearance and Via and Track and Pad
11.sardtra@allit.info
