Altera Simulation Problem
mohd_ind00
Junior Member level 3
Hi all..,
I am using Altera Quartus II 4.1 ver, there is problem in simulation,
1. The signals are automatically generated as results instead of existing signals in stimulus file, but the reults are not changing in the orignal signals, how to disable this or to get orignal signals activated?
2. While selecting the bus using Node Finder dialog box, two signal for same bus are appearing that one individual signal names and one bus name(one assigned and one Unassigned) which to select and/or both are same?
Put some light on this if any body can!
