altera ramstyle attribute
manojkhandelwal
Member level 2
Iam trying to infer MLABs or M512 etc....for my RAM implementation
But even if i apply the ramstyle attribute at the variable declaration ,RAM is not getting inferred.
Does any one know the reason....
The code that you have written to infer the RAM performs a different function than what can be implemented in the internal memory. My first guess is that you haven't registered the memory outputs before using them. In any case, you should refer to the Altera manual where you will find a section on how to write the code to infer memory properly. That is the code you want to use.
Kevin Jennings
here is the code
module my_ram(
                      //Inputs
                      clk,    //clock
                      wr_en,  //write enable
                      rd_en,  //read enable
                      addr,   //address
                      data_in,//data in
                      //Output
                      data_out//data out
  //Parameter Declaration
  parameter DEPTH = 8; //depth of FIFO
  parameter  ADDR_BUS_WD = 3; //Address bus width
  parameter  DATA_BUS_WD = 8; //data bus width
  //Inputs Declarations
  input  clk;                         //Clock
  input  wr_en;                       //Write Enable
  input  rd_en;                       //Read Enable
  input  [ADDR_BUS_WD-1:0] addr;      //Address Width
  input  [DATA_BUS_WD-1:0] data_in;   //Data Input
  //output Declarations
  output [DATA_BUS_WD-1:0] data_out;  //Data Output
  //reg Declarations
  reg [DATA_BUS_WD-1:0] mem [DEPTH-1:0]/*synthesis ramstyle = "MLAB" */;//Memory
  reg [DATA_BUS_WD-1:0] data_out;      //Data Output
  //Generation of data_out
  always @(posedge clk)
    begin : READ_GEN
      if(rd_en)  data_out <= mem[addr];
    end
       //Generation Writing data into memory
    begin: WRITE_GEN
      if(wr_en)  mem[addr] <= data_in;
    end
  endmodule
I think, the problem is with the read enable signal. Altera block RAM is registering the read address, it isn't able to register the output as well within a single clock cycle. You can also refer to the Verilog and VHDL design templates in the Quartus editor context menu.
make your ram bigger, say 8x512, and try;
with some sets of settings quartus implements small 2d reg
as registers instead of ram;
check also:
settings->analysis & synthesis settings -> more settings -> 'auto ram to logic cell conversion'
and read compilation messages carefully
J.A
There is no such setting as "auto ram to logic cell conversion"
can u give me exact settings that i need to apply in "analysis and synthesis settings"..> "more settings menu"......so that RAM is being inferred
because i personally feel there is a problem out there.
Thanks in advance
Which version are you using?
9.1 & 11.0, target device stratix2;
both tools implemented correctly your ram ( and both have the setting I mentioned )
check carefully compile messages, quartus produces a warning/info if a ram
is recognized but for any reasons can not be implemented;
and check fitter report - are you sure your 'mem' has been converted into
registers ?
J.A
Sorry for the late response.....i was off my working system,
the above code now maps to MLABs
Hers an asynchronous read ram with reset signal also....
this is not mapping onto an MLABs......actually i need to implement an asynchronous ram with reset as well
module my_ram(clk,rst_n,wr_n,rd_addr,wr_addr, data_in,  data_out  );
parameter data_width=8;
parameter depth=16;
input                          clk;
input                          rst_n;
input [3 : 0] rd_addr;
input [3 : 0] wr_addr;
input [data_width-1:0]         data_in;
input                          wr_n;
output [data_width-1:0]        data_out;
reg [data_width-1:0]  data_out;
reg [data_width - 1 : 0]  mem1 [depth-1:0] /* synthesis syn_ramstyle = "MLAB" */ ;
wire [data_width - 1 : 0] mem;
integer i;
//MEM implementation - asynchronous
always @( posedge clk or negedge rst_n )
	begin
   if ( !rst_n )
		begin
    for ( i = 0; i < depth; i = i + 1 )
      begin
          mem1[i] <= 0;
      end
		end
   else
    begin
       if (!wr_n  && (wr_addr<=depth-1))
          mem1[wr_addr] <= data_in;
     end
	end
assign mem = mem1[rd_addr];
always @ *
	begin
		if (rd_addr > depth-1)
	  	 data_out = 0;
		else
		   data_out = mem;
	end
endmodule
Thanks in advance
If you review the FPGA hardware manual, you'll understand why it can't be implemented in FPGA internal RAM, it's strictly synchronous.
Hi FvM,
in the manual it is given that MLABs can be configured for asynchronous read.....
in my case the write is synchronous and read is asynchronous......
Thanks
manoj
Yes, MLAB actually means Memory in Logic Array Block. MLAB can work asynchronously as well.
I'm not sure, how MLAB memory is displayed in the synthesis report. I'm not using Stratix III.
So, when it can work asynchronously why not quartus tool infer it for my asynchronous read RAM??????
is it just because of the reset signal?
Iam having hard time working with the quartus tool.....someone please help....
Thanks in advance,
manoj
If you read the compilation messages thoroughly, you'll find the exact reason for not inferring RAM. The respective restriction of MLAB RAM is also discussed in the Quartus software handbook.
Info: Found 1 instances of uninferred RAM logic
Info: RAM logic "mem1" is uninferred due to unsupported read-during-write behavior
