Altera RAM "pass-through logic" warning?
Artlav
Full Member level 2
Full Member level 2
Hello.
I'm trying to make a RAM for a cpu core out of the memory blocks in an Altera Cyclone FPGA (EP1C3).
Everything synthesises well, and it works fine in the simulation, but something does not work on real hardware.
The only suspicious thing left is this warning i get for the memory in question:
Warning: Inferred RAM node "inram_controller:inramc|memory_rtl_0" from synchronous design logic. Pass-through logic has been added to match the read-during-write behavior of the original design.
What does it mean and how to fix it?
Can it cause problems, or is it safe to ignore?
I've been trying to rearrange the access in various ways, i.e.
 data2cpu <= memory[mem_addr];
 if (wea) begin
  data2cpu <= tmp_mem;
  memory[mem_addr] <= tmp_mem;
 end
Buffer the input data and/or address, and other things suggested around places that Googling the error gives, but it changes nothing.
Any help will be appreciated.
module inram_controller(
 input rst,
 input clk,
 input os_write_lock,
 input  [31:0] addr,
 input  [31:0] data2mem,
 output reg [31:0] data2cpu,
 input  re,
 input  we,
 output reg done
wire p=re|we;
reg [9:0] mem_addr;
reg [1:0] state;
reg [31:0] tmp_mem;
parameter [1:0] inram_idle = 2'd0;
parameter [1:0] inram_op   = 2'd1;
parameter [1:0] inram_skip = 2'd2;
reg [31:0] memory[1023:0]; //1024*4=4kb
integer n;
initial begin
 for (n = 0; n < 1024; n = n + 1) memory[n] = 0;
 memory[0] = 32'h0B0B0B0B;
 memory[1] = 32'h80A00894;
 memory[2] = 32'h0B0C0A81;
 memory[3] = 32'h800B0B0B;
 memory[4] = 32'h00000004;
 memory[5] = 32'hFFFFFFFF;
end
always @(posedge clk)
begin
 if (rst) begin
  //$display("inram_reset");
  state <= inram_idle;
  data2cpu <= 0;
  done <= 0;
  mem_addr <= 0;
 end else begin
  case (state)
   inram_idle: begin
    //$display("inram_idle: we=%d, re=%d", we, re);
    done <= 0;
    if (p) begin
     state <= inram_op;
     mem_addr <=a ddr[11:2];
     tmp_mem <= data2mem;
    end
   end
   inram_op: begin
    $display("inram_op: %d(%d), we=%d, re=%d", addr, mem_addr, we, re);
    if (we) memory[mem_addr] <= tmp_mem;
    else if (re) data2cpu <= memory[mem_addr];
    done <= 1;
    state <= inram_skip;
   end
   inram_skip: begin
    done <= 0;
    mem_addr <= 0;
   end
  endcase
 end
end
endmodule
Full report:
    Info: Inferred altsyncram megafunction from the following design logic: "inram_controller:inramc|memory_rtl_0"
        Info: Parameter OPERATION_MODE set to DUAL_PORT
        Info: Parameter WIDTH_A set to 32
        Info: Parameter WIDTHAD_A set to 10
        Info: Parameter NUMWORDS_A set to 1024
        Info: Parameter WIDTH_B set to 32
        Info: Parameter WIDTHAD_B set to 10
        Info: Parameter NUMWORDS_B set to 1024
        Info: Parameter ADDRESS_ACLR_A set to NONE
        Info: Parameter OUTDATA_REG_B set to UNREGISTERED
        Info: Parameter ADDRESS_ACLR_B set to NONE
        Info: Parameter OUTDATA_ACLR_B set to NONE
        Info: Parameter ADDRESS_REG_B set to CLOCK0
        Info: Parameter INDATA_ACLR_A set to NONE
        Info: Parameter WRCONTROL_ACLR_A set to NONE
        Info: Parameter INIT_FILE set to db/ep_test.ram0_inram_controller_8b3d01f9.hdl.mif
        Info: Parameter READ_DURING_WRITE_MODE_MIXED_PORTS set to OLD_DATA
This circuitry is standard. The code you have written asks that if the read address and write address clash during the same clock cycle, it should read the old data back before it writes the new data. This requires extra logic around the ram, as the warning suggests.
Could you elaborate on that?
I tried it like that
And like that
  case (state)
   inram_idle: begin
    done <= 0;
    if(p) begin
     mem_addr <= addr[11:2];
     if (we) state <= inram_wr;
     if (re) state <= inram_rd;
    end
   end
   inram_rd: begin
    done <= 1;
   end
   inram_wr: begin
    memory[mem_addr] <= data2mem;
    done <= 1;
   end
   inram_skip: begin
    done <= 0;
    mem_addr <= 0;
   end
  endcase
With no effect on the warning.
I see not clash in either.
