Altera DE2 UART Help!
rayyanc
Newbie level 2
Hey all,
I'm not the most tech savvy of people but somehow I got a code for a UART to actually program onto my FPGA. What I aim to do is to connect my board to my laptop so that I can send information through Matlab via the serial port. When I program my code onto the board, I see the TXD light turn green but the RXD light turn red, I assume that that means whatever I've done isn't working and so my receiver doesn't work. Right now what I'm trying to do is just basic, I'm going to send information through Matlab to light up LEDR0 through LEDR7 depending on whatever is sent on Matlab. The codes I'm using are as follows:
module MatlabConnect(clk, RxD, TxD, GPout, GPin, LEDR);
// Create 8 outputs on the FPGA - GPout is updated by any character that
// the FPGA receives. Create 8 inputs on the FPGA - GPin is transmitted
// every time the FPGA receives a character.
input        clk;
input        RxD;
input [7:0] GPin;
output         TxD;
output [7:0] GPout;
output [7:0]  LEDR;
wire RxD_data_ready;
wire [7:0] RxD_data;
async_receiver deserializer(.clk(clk), .RxD(RxD), .RxD_data_ready(RxD_data_ready), .RxD_data(RxD_data));
reg [7:0] GPout;
always @(posedge clk) if(RxD_data_ready) GPout <= RxD_data;
async_transmitter serializer(.clk(clk), .TxD(TxD), .TxD_start(RxD_data_ready), .TxD_data(GPin));
assign LEDR[0] = GPout[0];
assign LEDR[1] = GPout[1];
assign LEDR[2] = GPout[2];
assign LEDR[3] = GPout[3];
assign LEDR[4] = GPout[4];
assign LEDR[5] = GPout[5];
assign LEDR[6] = GPout[6];
assign LEDR[7] = GPout[7];
endmodule
module async_receiver(clk, RxD, RxD_data_ready, RxD_data, RxD_endofpacket, RxD_idle);
input clk, RxD;
output RxD_data_ready;
output [7:0] RxD_data;
// Set the Clock frequency to 25MHz and the Baud rate to 115200Hz
parameter ClkFrequency = 25000000;
parameter Baud = 115200;
// Detect if a gap occurs in the received stream of characters; useful if
// multiple character are sent in a burst so that multiple characters can
// be treated as a packet
output RxD_endofpacket;  // One clock pulse, when no more data is received (RxD_idle is going high)
output RxD_idle;         // No data is being received
// Baud generator, using 8 times oversampling
parameter Baud8 = Baud*8;
parameter Baud8GeneratorAccWidth = 16;
wire [Baud8GeneratorAccWidth:0] Baud8GeneratorInc = ((Baud8<<(Baud8GeneratorAccWidth-7))+(ClkFrequency>>8))/(ClkFrequency>>7);
reg [Baud8GeneratorAccWidth:0] Baud8GeneratorAcc;
always @(posedge clk) Baud8GeneratorAcc <= Baud8GeneratorAcc[Baud8GeneratorAccWidth-1:0] + Baud8GeneratorInc;
wire Baud8Tick = Baud8GeneratorAcc[Baud8GeneratorAccWidth];
// Asynchronous Receiver
reg [1:0] RxD_sync_inv;
always @(posedge clk) if(Baud8Tick) RxD_sync_inv <= {RxD_sync_inv[0], ~RxD};
// We invert RxD, so that the idle becomes "0", to prevent a phantom
// character to be received at startup
reg [1:0] RxD_cnt_inv;
reg RxD_bit_inv;
if(Baud8Tick)
begin
	if( RxD_sync_inv[1] && RxD_cnt_inv!=2'b11) RxD_cnt_inv <= RxD_cnt_inv + 2'h1;
	else
	if(~RxD_sync_inv[1] && RxD_cnt_inv!=2'b00) RxD_cnt_inv <= RxD_cnt_inv - 2'h1;
	if(RxD_cnt_inv==2'b00) RxD_bit_inv <= 1'b0;
	else
	if(RxD_cnt_inv==2'b11) RxD_bit_inv <= 1'b1;
end
reg [3:0] state;
reg [3:0] bit_spacing;
// "next_bit" controls when the data sampling occurs depending on how
// noisy the RxD is, different values might work better with a clean
// connection, values from 8 to 11 work
wire next_bit = (bit_spacing==4'd10);
if(state==0)
	bit_spacing <= 4'b0000;
else
if(Baud8Tick)
	bit_spacing <= {bit_spacing[2:0] + 4'b0001} | {bit_spacing[3], 3'b000};
if(Baud8Tick)
case(state)
	4'b0000: if(RxD_bit_inv) state <= 4'b1000;  // Start Bit found?
	4'b1000: if(next_bit) state <= 4'b1001;     // Bit 0
	4'b1001: if(next_bit) state <= 4'b1010;     // Bit 1
	4'b1010: if(next_bit) state <= 4'b1011;     // Bit 2
	4'b1011: if(next_bit) state <= 4'b1100;     // Bit 3
	4'b1100: if(next_bit) state <= 4'b1101;     // Bit 4
	4'b1101: if(next_bit) state <= 4'b1110;     // Bit 5
	4'b1110: if(next_bit) state <= 4'b1111;     // Bit 6
	4'b1111: if(next_bit) state <= 4'b0001;     // Bit 7
	4'b0001: if(next_bit) state <= 4'b0000;     // Stop Bit
	default: state <= 4'b0000;
endcase
reg [7:0] RxD_data;
if(Baud8Tick && next_bit && state[3]) RxD_data <= {~RxD_bit_inv, RxD_data[7:1]};
reg RxD_data_ready, RxD_data_error;
begin
	RxD_data_ready <= (Baud8Tick && next_bit && state==4'b0001 && ~RxD_bit_inv);  // Ready only if the Stop Bit is received
	RxD_data_error <= (Baud8Tick && next_bit && state==4'b0001 &&  RxD_bit_inv);  // Error if the Stop Bit is not received
end
reg [4:0] gap_count;
always @(posedge clk) if (state!=0) gap_count<=5'h00; else if(Baud8Tick & ~gap_count[4]) gap_count <= gap_count + 5'h01;
assign RxD_idle = gap_count[4];
reg RxD_endofpacket; always @(posedge clk) RxD_endofpacket <= Baud8Tick & (gap_count==5'h0F);
endmodule
module async_transmitter(clk, TxD_start, TxD_data, TxD, TxD_busy);
input clk, TxD_start;
input [7:0] TxD_data;
output TxD, TxD_busy;
// In RegsiterInputData mode, the input doesn't have to stay valid while
// the character is being transmitted
parameter RegisterInputData = 1;
// Baud generator
parameter BaudGeneratorAccWidth = 16;
reg [BaudGeneratorAccWidth:0] BaudGeneratorAcc;
`ifdef DEBUG
wire [BaudGeneratorAccWidth:0] BaudGeneratorInc = 17'h10000;
`else
wire [BaudGeneratorAccWidth:0] BaudGeneratorInc = ((Baud<<(BaudGeneratorAccWidth-4))+(ClkFrequency>>5))/(ClkFrequency>>4);
`endif
wire BaudTick = BaudGeneratorAcc[BaudGeneratorAccWidth];
wire TxD_busy;
always @(posedge clk) if(TxD_busy) BaudGeneratorAcc <= BaudGeneratorAcc[BaudGeneratorAccWidth-1:0] + BaudGeneratorInc;
// Asynchronous Transmitter
reg [3:0] state;
wire TxD_ready = (state==0);
assign TxD_busy = ~TxD_ready;
reg [7:0] TxD_dataReg;
always @(posedge clk) if(TxD_ready & TxD_start) TxD_dataReg <= TxD_data;
wire [7:0] TxD_dataD = RegisterInputData ? TxD_dataReg : TxD_data;
case(state)
	4'b0000: if(TxD_start) state <= 4'b0001;
	4'b0001: if(BaudTick) state <= 4'b0100;
	4'b0100: if(BaudTick) state <= 4'b1000;  // Start
	4'b1000: if(BaudTick) state <= 4'b1001;  // Bit 0
	4'b1001: if(BaudTick) state <= 4'b1010;  // Bit 1
	4'b1010: if(BaudTick) state <= 4'b1011;  // Bit 2
	4'b1011: if(BaudTick) state <= 4'b1100;  // Bit 3
	4'b1100: if(BaudTick) state <= 4'b1101;  // Bit 4
	4'b1101: if(BaudTick) state <= 4'b1110;  // Bit 5
	4'b1110: if(BaudTick) state <= 4'b1111;  // Bit 6
	4'b1111: if(BaudTick) state <= 4'b0010;  // Bit 7
	4'b0010: if(BaudTick) state <= 4'b0011;  // Stop 1
	4'b0011: if(BaudTick) state <= 4'b0000;  // Stop 2
	default: if(BaudTick) state <= 4'b0000;
endcase
// Output mux
reg muxbit;
always @( * )
case(state[2:0])
	3'd0: muxbit <= TxD_dataD[0];
	3'd1: muxbit <= TxD_dataD[1];
	3'd2: muxbit <= TxD_dataD[2];
	3'd3: muxbit <= TxD_dataD[3];
	3'd4: muxbit <= TxD_dataD[4];
	3'd5: muxbit <= TxD_dataD[5];
	3'd6: muxbit <= TxD_dataD[6];
	3'd7: muxbit <= TxD_dataD[7];
endcase
// Put together the start, data and stop bits
reg TxD;
always @(posedge clk) TxD <= (state<4) | (state[3] & muxbit);  // register the output to make it glitch free
endmodule
Any and all help is appreciated! Also, please try to explain things really simply...like I said I'm quite inept when it comes to these things
